Zone 2 AMP recommendations
Username: Kfree1966
Post Number: 17
Currently have an Arcam AVR 300 and want to drive a set of speakers with the Zone 2 output. The Zone 2 output provides line level. Need to get a low cost (sub $300) amp to drive the speakers. any recommendations
Username: Jan_b_vigne
Dallas, TX
Post Number: 8165
Audio Source. The advertisements for this amp appear on the forum with regularity. However, it depends on how many speakers you intend to drive with one amplifier and how you intend to make the connection between amp and speakers.
Username: Nuck
Post Number: 2029
Kevin, that is one heck of a nice receiver.
Doesn't the Zone 2 use the 6th and 7th channels as Zone 2?
Or maybe you are using all 7?
Username: Hawk
Highlands Ranch, CO USA
Post Number: 765
What speakers will you use in zone 2?
Username: Kfree1966
Post Number: 18
Nuck, you were right. Read the book and did some fiddling around. I can use channel 6 & 7 for the second zone. The only issue is I have to dual connect my CD player. Digital connect for Zone 1 and Analog for Zone 2.
As for the Zone 2 speakers, there are 2 sets of KEF wall mounts and Boston Acoustics on deck.
I would have liked to run HT, but mrs. has to redecorate and has that on hold. Brought the receiver as a cheaper setup then the AV8/P7 combo.
Thanks,
