Amp Help
Username: Cowdood
I was looking at the Fender G-Dec amp at a used guitar store and found several of them with some problems. One of them had a broken volume control, another had trouble keeping power, etc. My question is which one of these would be the easiest to repair and if possible, help on how to do so. Also, the amp is digital if that makes a difference. Thanks.
Here is the amp: <a href="http://www.fender.com/products/search.php?partno=2350000000">
(I'm guessing the volume one but just making sure)
Username: Jan_b_vigne
Dallas, TX
Post Number: 8159
If one of the amplifiers has only mechanical problems, that will probably be the easiest to repair. How? I don't know without knowing more about the amplifier and the problem. Mechanical parts are often just a drop in replacement.
