New member Username: Robert_kayVenice, CA United States Post Number: 1 Registered: Apr-06 | Anyone have any thoughts on this combo? I'm a lifelong NAD guy new to the world of surround, and I'm looking to upgrade. Just wondering if anyone has anything good/bad to say about this combo? Thanks in advance for any help. |
Silver Member Username: HawkHighlands Ranch, CO USA Post Number: 755 Registered: Dec-03 | Robert: My dealer died and her shop was recently closed, but before that happened, I used to go in just to listen to the T163/973 combo--it really is superb. This dealer had an Anthem pre/pro and amp setup for demos, but replaced it with the NADs about 15 months ago. I must say, the NADs sounded more open and with a larger soundstage than the Anthem system (which cost twice as much) which is no slouch. For the money, it is hard to see where you can go wrong, particularly since you like the NAD sound. |
New member Username: Robert_kayVenice, CA United States Post Number: 2 Registered: Apr-06 | Thanks for the advice Hawk. The only negatives I've read are the lack of Dobly PLIIx, and problems with bass management while using it in stereo mode. The reviews I read were from early 2005 so I'm not sure if NAD has addressed this already. I mainly listen to music through my system, but want to be able to expand into surround. Right now I'm looking to purchase a new 7.1 combo, a center speaker, and a sub. Thanks again for the advice. |
Silver Member Username: Unbridled_idChicagoUsa Post Number: 158 Registered: Mar-04 | http://www.northamptonaudio.com/nad/potentpair.asp |
Bronze Member Username: Stephen_mPost Number: 14 Registered: Aug-05 | Robert, Both of those issues have been addressed in the 'V2' units. Enjoy! |
New member Username: Robert_kayVenice, CA United States Post Number: 3 Registered: Apr-06 | Thanks for all the advice, and the link. I'm really looking forward to hooking this up! |
Silver Member Username: DakulisSpokane, Washington United States Post Number: 887 Registered: May-05 | Robert, If you don't mind Refurbished, take a look at this link at Spearitsound. http://www.spearitsound.com/nad/potentpair.asp Save a few bucks and get your NAD and "no" I don't work for them. LOL Dave |
New member Username: Robert_kayVenice, CA United States Post Number: 4 Registered: Apr-06 | Thanks again all for the good advice. Happy to have stumbled upon this place. |
