Bronze Member Username: SummitPost Number: 13 Registered: Mar-06 | Help! I've been on the hunt for a decent sub. I already narrowed my picks to Polk PSW404, B&W ASW600, Paradigm PDR10, Velodyne VX-10 (this one not yet heard), and Velodyne CHT-R10. In my place, these are all the available stuff I can find to my liking. And no Internet ordering in this side of the globe. Cost wise, the Polks and Paradigm cost the same, the ASW600 and CHT-r10 is more expensive than the Polks and Paradigm, while the VX-10 is cheaper by half of the polks and Paradigm. My problem is that the Polk PSW404 uses foam surrounds. Based on what I gathered, foam is not as durable as other surrounds, and repair kits is none existent here to say the least. Besides, I don't like the idea of having a bad surrounds after 5 years. Can anyone give me the lowdown on foam surrounds, I live in temperate to warm climate. And any thoughts on the Velodyne VX-10? Thanks. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 8141 Registered: May-04 | Foam surrounds will eventually dry and crack though it normally takes far more than five years. If you don't want to replace a worn out speaker, don't buy one with foam surrounds. |
Silver Member Username: TwebbzAnn Arbor, Michigan USA Post Number: 381 Registered: Apr-04 | I had Large Advents with great walnut cabinets from the mid 80's. The woofers had foam surrounds. It took ten years for the foam to disinigrate. I replaced the woofers ($100 each). Ten more years went by and the foam started to separate from the cones. I got out the rubber cement and did a great job of fixing them up. Sold them to a college student for $50. Not bad for 20 years of service. |
Bronze Member Username: SummitPost Number: 14 Registered: Mar-06 | Thanks. I wonder what is the conservative estimate for a foam surround to start degrading with noticeable effect to performance? And will a warm climate accelerate the process? Thanks. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 8156 Registered: May-04 | Your best place for that information is the manufacturer of the specific subwoofer with a foam surround you are considering. Not all foam surrounds are the same and the maker can advise on theirs. |
Bronze Member Username: SummitPost Number: 15 Registered: Mar-06 | Thanks again. I think I'm gonna play it safe and stick with rubber surrounds. |
Gold Member Username: Thx_3417Post Number: 1393 Registered: May-05 | Hears is a link to re-edging loudspeakers. http://www.simplyspeakers.com/2doityourself.htm |
