i have pionner d914 receiver and its cooler doesnt work at low volumes, only works around -27db. and for this its getting kinda hot. do you know if this is ok or not? normal for receivers getting hot? i have a proper setup. thanks
If you have anything sitting on top of the receiver you should remove it. Or if the receiver is in a confined space, it may need more room for air circulation.
If your speakers are inefficient or are of the 4 ohm variety, that could be causing amp problems. What speakers are you driving?
