Should i do this? HELP
Username: Toxus
iv put two JACK leads into one terminal, is it ok to do? its only a micro system. If im not ment to do this, how do i plug more than 2 speakers into it?
thanks for any helpUpload
Username: Gamerdude
Kitchener, Ontario Canada
yes you can do it along as you carful if all the speakers are the same ohms such as..6ohm amp 6+ ohms speakers
or go to you r local bestbuy/futureshop/surplus store
http://www.amazon.com/gp/product/B0000695AT
and get a speaker selecter its what i did with my philips 175/channle2
Need to Register?
Forgot Password?
Enable HTML code in message
