NAD c162 and c272
Username: Wick1000
I am ordering the NAD c162 and c272.
What inter-connects would you recommend to get the most out of this set up? I don't want to spend more than ~$100.
Also, how would you recommend to wire my speakers...Monitor Audio S6's? I am a bit of a novice...not sure what bi-wiring is etc. Quality of speaker wire, best connector type etc.
Any advice would be appreciated.
Thanks for your input,
David
Username: Unbridled_id
ChicagoUsa
Post Number: 149
http://www.bluejeanscable.com/
ChicagoUsa
Post Number: 150
Congrats on your purchase, I own the amp and it's fantastic.
Username: Hoanghai2k
Melbourne, VIC Australia
Post Number: 13
i just wonderring what speaker better to go with that set 162/272
Username: Wick1000
I have Monitor Audio S6.
Also, I was wondering how many hours does it take to break in the amp? What is the best method? Leave it on overnight a few nights, with the volume tuned down or just regular listening and try to be patient?
wick1000
Username: Ellison
Post Number: 48
I use Ixos for interconnects and ecosse for speaker cable. I suggest leave it on for 1 week and playing as much as possible... I use Mordaunt Short 914 floorstander...
Username: Dakulis
Spokane, Washington United States
Post Number: 904
Here you go. Just remember, this is only about 24" long. So, if you need it longer, talk with Mikey first and get a price on a longer piece. But, it really opened up my sound and at the winning bid price, it was well worth the wait from England. Not only pretty but they taste good, too. Good luck, Dave
http://cgi.audiogon.com/cgi-bin/auc.pl?cablintr&1144977977
