I have a technics sl-b202. My problem with it is that the right channel is really fuzzy and distorted. I know that its the turntable and not the amplifier, because i've tested it with two amps, and came out with the same results. Any ideas? thanks
You need to adjust the tracking. Play with the knob at the very back of the arm. (sorry if I'm not using the correct terminology; I'm new at this).
Make sure your turntable is level and adjust the knob in one direction and then the next (headphones work best for this). Once the problem is corrected, reduce the amount you have applied until you get to the lowest pressure neccesary to hear both left and right equally.
