Bronze Member Username: Talon_es93Post Number: 88 Registered: Mar-06 | what amp do i need for this???![]() ![]() |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 1033 Registered: May-05 | One of these for each speaker should do nicely- http://mcintoshlaboratory.tripod.com/aa/mc1201.htm Or one of these per speaker when they come out- http://mcintoshlaboratory.tripod.com/aa/mc2kw.htm |
Bronze Member Username: Talon_es93Post Number: 92 Registered: Mar-06 | well i mainly need an amp for my 18s |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 1036 Registered: May-05 | I don't think the mac's will have any problems driving anything. |
Bronze Member Username: Talon_es93Post Number: 93 Registered: Mar-06 | i dont' need to much... i would like to have just one about to push all the speaker...and if it could have the surround sound thing that even better...idk sh!t about home audio... i'm more of a car audio guy so i really need help on this |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1717 Registered: Dec-04 | Apparantly. Please identify each of the speakers you have pictured,so as to offer assistance. |
Bronze Member Username: Talon_es93Post Number: 94 Registered: Mar-06 | this guy sounds like he knows his sh!t.... alright theres the peaveys SP118X and prostudios mach II and my favorit... the cerwin vega LS-12s |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1730 Registered: Dec-04 | Indeed, I shall compile a series of scenarios for your perusal. |
Bronze Member Username: Talon_es93Post Number: 95 Registered: Mar-06 | thanks but don't talk so smart b/c in school i never had nothin better then a C |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1732 Registered: Dec-04 | bid on the 6.6 on ebay right now. 450$ |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1733 Registered: Dec-04 | The classic 6.6, sorry |
Bronze Member Username: Talon_es93Post Number: 96 Registered: Mar-06 | but can that push my 18"s? |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 1038 Registered: May-05 | .D. - The McIntosh amps suggestion was a joke. Unless of course you have about $8,000 to spend on each mono amp. |
Bronze Member Username: Talon_es93Post Number: 99 Registered: Mar-06 | hell naw freak that.. i juss want this for my room... just something that can push my 18"s... and have that surround sound if possible |
Bronze Member Username: IrisfailsafeBogotaColombia Post Number: 21 Registered: Jan-06 | you need big amps, can you give us the specs of the speakers... I suggest you visit the sites of: mark levinson and classe just google them out |
Gold Member Username: Project6Post Number: 7308 Registered: Dec-03 | I don't think refinement is key in this set-up. Have you looked at professional power amps? Check out Crown Power amps. http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=3&manufacturer=270&sm= 2&so=1 Some of these bad boys will drive your speakers with ease and very loud at that. You should be able to find one that will fit your budget. |
