NAD AV-716 radio presets
Username: Javmeister
London, London UK
Does anyone know how to set the radio presets on a NAD AV-716 reciever amp? There is a memory button and a keypad, looks like a calculator keypad. I have tried every damn combination of buttons to save the radio stations and it won't save the frequencies in the presets. If anyone knows or anyonw has a similar NAD receiver then your help is much appreciated....
Username: Nottingham365
MA USA
Try the NAD site. Manuals are available on line for AV surround sound receivers 711 and 713. (Use adobe acrobat software to view manuals). Perhaps the procedure is the same.
http://www.nadelectronics.com/support/manuals_framset.htm
London, London UK
I looked at one of the manuals and there is a similar setup in AV711 manual. I will try it out tonight when i get home and let the forum know how it goes, thanks for the tip Ross.
London, London UK
Well done Ross. The new user manuals did the trick. Its a crazy complicated procedure that NAD have engineered to store presets. Both the 711 and 713 have the same procedure as my 716.
MA USA
Javed,
Great news!
Happy listening.
Ross
