NTSC_PAL Unregistered guest | Okay, dumb question of the day: If I have a receiver from the US in a PAL setup, i.e. the DVD is in PAL mode and the TV is also PAL, will it work? |
New member Username: Chinna_nPost Number: 4 Registered: Apr-04 | What kind of receiver? for audio there should not be a problem at all. For video also there should not be a problem unless you use composite to s-video conversion built in receiver(even that may not be a problem, but not sure). Otherwise it simply acts as relays for video. |
NTSC_PAL Unregistered guest | Chinna Na, I was planning to buy an HK AVR230. I thought it should act as a relay for the video but I saw in the specs there was a note that stated "Video output format :NTSC". ( http://www.harmankardon.com/specifications.asp?cat=REC&ser=&prod=AVR%20230&sType =C ). This got me confused. When you say "composite to s-video conversion" what does it mean? Thanks. |
