New member Username: Subabu2002Erode,, Tamil nadu,i... India Post Number: 1 Registered: Apr-04 | hi all, i was confused to select the polk psw 202 for my av receiver.(pioneer vsx d 711) no other sub is not possible for buy because of various circumstances my dout is, 1.this sub(polk psw202) is 50 watts powered but my receiver is 100watts power,so if i will used this sub then any problem can happen? 2.if possible to use this sub with my receiver ,then it does will produce enough bass for my room?? because it`s power is 50 watts but my room size is 17*17 and 12feet height. so,50 watts is enough for my room size?? please help to clear the douts, |
New member Username: Subabu2002Erode,, Tamil nadu,i... India Post Number: 2 Registered: Apr-04 | hi, any body knows yamaha yst-sw 320.. my room size is 17 * 17 . so,does it will produce enough bass to fill up this room. or then.?? |
shank Unregistered guest | i think the 50watts is prolly the RMS wattage, prolly not the peak/dynamic wattage. Polk's site says it has a peak/dynamic wattage of 100watts. If you check polk's website (http://www.polkaudio.com/home/), they had a subwoofer wizard/configurator, where you could input your room size, and it will tell you how many decibels the subwoofer and produce for that room. |
