Bronze Member Username: MrlorenChulaJuna, CA Post Number: 16 Registered: Nov-05 | Hello, Has anybody heard these? right now I have RTi4's and they are good but I want to use the pre wire in my home. I can get a good deal on a pair for about $350. They will be used for the front main speakers. http://www.polkaudio.com/homeaudio/products/tc80i/ |
Silver Member Username: KanoBC Canada Post Number: 883 Registered: Oct-04 | Generally I'd say it's best to use in-wall/ceiling speakers for surround duty, or for a second room for ambient sound. I would suspect the Rti4s would even perform better in the front position. |
Bronze Member Username: Armyscout42DUGWAY , UTAH USA Post Number: 54 Registered: Sep-04 | polk makes in-walls too, I used to install them on some homes including mansions in which the the customer didn't want to spend more than 30k for an entire home theater system. whatever sounds good to you and fits your decor! |
