Volume control on the master speaker The volume control on my master speaker has unfortunately snapped off after falling off my shelf. It has broken away from the connections inside the speaker, and really would like some advice as to what to do, can i replace the specific parts and fix the volume control. Alternatively can I buy a new speaker separately to the rest of the set. I emailed the technical/product support division of Logitech and gained no further insight into my situation. Your advice on the matter would be greately appriciated
Can you not reconnect the volume control to the (now) loose wires? A less recommended solution would be to short the loose ends of the wires, and use the volume control on the CD player or computer.
