Best Bookshelf for Small Room
Username: Cstrife90
Hi, I am looking for a good bookshelf system between 100 and 400 dollars. I will be using the system for 80 % music and 20 % movies. The speakers will be in a small/medium size room. I am looking for a warm and clear sound, and do not want treble or bass that is fatiguing. So far, the only two speakers which I am considering is the JBL e50 and the Axiom M3T - which is better? Any other suggestions? Thanks.
Username: Twebbz
Ann Arbor, Michigan USA
Post Number: 371
Axioms will be bright. I tried and returned the M50Ti towers and thought that the midrange was colored due to the aluminum bass drivers. Since the M3T uses this bass driver also, I suspect it would sound similar.
Username: Jan_b_vigne
Dallas, TX
Post Number: 7858
http://www.us.alegriaaudio.com/products.htm
Username: Chitown
Post Number: 861
Sinan I own th M3t's in my HT setup with a Marantz. I do like them for my rather good sized living room, but you might want something a little smaller and warmer for a small setup.
Although I haven't heard them myself, Jan's suggestions has received good accolade here. You might also give Aperion a try. If you don't mind spending a little more, give a try to Monitor Audio.
Username: Edster922
Post Number: 3693
ascendacoustics.com
