New member Username: HonusMiami, FL USA Post Number: 3 Registered: Mar-06 | I've been tinkering with various receivers and was looking for some feedback from you knowledgeable folks. In my bedroom I listen to music/TV ONLY through headphones, no speakers. Since I'm looking for great stereo sound, I don't think I need to go into the world of 'home theater' multi channel receivers as you can't hear all the channels through headphones anyway. I currently have an Onkyo TX-8511 which works pretty well and then acquired a Marantz PM7200 but can't get that to work without using 'Sound Direct'. That limits my possibilities of tweaking the sound. What would you recommend as a good receiver/amp for use exclusively with headphones? |
Silver Member Username: KanoBC Canada Post Number: 872 Registered: Oct-04 | I'd suggest a tube headphone amp for the best results. http://www.audioadvisor.com/store/productdetail.asp?sku=ASLHB1&product_name=HB1% 20Hybrid%20Tube%20Headphone%20Amp (First one I found on Google) |
