Advice
Username: Kerwoo
Holland Landing, Ontario Canada
While researching HT Receivers I noticed onr feature the Onkyo line have is "Intellivolume."
This feature allows you to adjust input levels to even out volume differentials.
Can anybody advise me if any other Brands have this same feature?
Thanks in advance
Username: Jan_b_vigne
Dallas, TX
Post Number: 7820
Decades ago it was a fairly common item on better equipment. Back then it was done with trim pots and human intelligence. It is occasionally found on higher priced gear today. There's not too much need since the digital sources of today all output more or less the same voltage. Unless you are running a turntable, there shouldn't be extreme differences in level between most sources. As a rule, any circuit which makes a decision for you can often be viewed with suspicion as to what it is doing to the signal in other ways.
Username: Kerwoo
Right now I have an older Kenwood VR-410. It has been excellent, except when changing between inputs their is quite a difference.
I.E. FM-Loud
DVD-Soft
Cable Box-Normal
Etc.
Can you see what I mean?
Any suggestions?
Dallas, TX
Post Number: 7823
None unless you wish to install a trim pot in line with the louder sources.
Username: Nuck
Parkhill, Ontario Canada
Post Number: 1582
Kerwood, the older receiver isn,t expecting the varied inputs which it is now seeing.
Just that way.
New stuff expects all that jazz and is ready to trip or gain for somewhat more level delivery.
With questionable electronics in the path, yes.
