Boston Acoustics VR-M90...............Should I?
Username: Jeff_murphy
Are these a good choice? I had an earlier post about replacing my 901's. Yes I know it will be an improvement, but would like to know if the VR-M90's are worth the cost. Listen to mostly classic hard rock(70's and up). Rumour has it is that these will be discontinued in 9 months or so. http://www.bostonacoustics.com/home_product.aspx?product_id=188
Username: Bytesiz
Post Number: 7
Have you heard them yet? What else have you heard? How do they compare?
For that price, you have a very large number of choices. Start shopping!
