d anonymous Unregistered guest | I have two front speakers a center speaker and two rear speakers and a subwoofer I just got two more new front speakers an i was wondering if it would mess up my stereo if i plugged two speakers in to one hole on the back of my reciever |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1514 Registered: Dec-04 | still yes |
Silver Member Username: GavincummNew York USA Post Number: 764 Registered: Feb-05 | same response from me for the millionth time... DUH |
New member Username: AdadPost Number: 2 Registered: Mar-06 | I live in an apartment. I have a very simple (2 speaker) stereo system (and an old but good Yamaha R8 receivor). further, I'm not a computer geek or gamer or anything. How can I set it up so that my stereo system and computer utilize the same speakers. Please keep in mind that I'm on a budget. Thanks for any help |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3680 Registered: Mar-05 | buy some RCA analog cables ($5) and connect your soundcard to your receiver's "Aux" inputs. If your computer doesn't have a soundcard, buy this one: http://www.newegg.com/Product/Product.asp?Item=N82E16829120103 Apparently with its Wolfson DACs and Envy chipset that's the best budget soundcard for 2-channel music going. It even comes with an optical cable! Google it for a bunch of reviews. I might be buying one for myself soon too. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3681 Registered: Mar-05 | the above is assuming that your speakers are already connected to the receiver. If you only have PC speakers attached to the computer then you are out of luck unless your receiver has pre-outs. |
New member Username: AdadPost Number: 3 Registered: Mar-06 | I currently have 2 speakers hooked up to the stereo system and 2 different speakers hooked up to the computer. Neither my stereo speakers nor the receivor accommodate RCA jacks. I was going to get a good set of speakers (for music) because all I have right now is the cheapies that came with the computer and I'd like to get the space back that the stereo system speakers take up. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3684 Registered: Mar-05 | Maybe you've misunderstood me. I'm saying, keep your stereo speakers hooked up to the receiver just the way they are right now. Just connect your PC's sound card to the receiver using RCA jacks. I find it hard to believe that your receiver does not even have ONE set of auxilary inputs. Even my POS Sony minisystem has one set of RCA inputs. |
Gold Member Username: Project6Post Number: 6754 Registered: Dec-03 | What kind of receiver is it? Or is it a big radio? |
