Old speakers repair...
Username: Stridergt
AthensGreec e
Post Number: 17
I have a pair of 1970s Philips 30W 3-way speakers. Inside one of them a metal round cap (around 3 cm diameter) was detached from the center of the woofer front surface. How can I glue the metal cap back on to the woofer? Can I use instant glue or will it destroy the woofer's membrane? Is there a special glue for this job? How does the metal cap affect the sound of the speaker, what is its purpose?
Username: Nuck
Parkhill, Ontario Canada
Post Number: 1511
It is a dust cover.
Glue it back on.
Oh, and 1970 called.
They want their speakers back.
And the van.
Username: Nuck
Post Number: 1512
In jest George, good luck.
Username: Jan_b_vigne
Dallas, TX
Post Number: 7733
The dust cap probably isn't needed on these speakers; it only does what the name implies. But, this could be the speakers trying to tell you something. If you must, place it back on the speaker with some contact cement.
Username: Davidpa
Portland, Oregon US
Post Number: 138
Jan, is this similar to the elmers glue trick? To stiffen woofers back up after years of abuse? Or am I that far off base?
Username: Stridergt
AthensGreec e
Post Number: 18
How can it be a dust cover since its so small (1.5 inches diameter) and inside the speaker cabinet?!?!?!
I had to unscrew the backplate of the speaker cabinet and the low freq speaker itself to find what was loose inside it. I have no access from the front side of the speaker cabinet which is covered with some kind of cloth. I know that it is glued with the low freq speaker membrane (centerspot), because I opened the other -intact- speaker too. It may add some weight or rigidness to the membrane but I do not know what type of glue to use??
Dallas, TX
Post Number: 7734
So far off, one of the Harlem Globetrotters Southpaws could pick off first.
Username: Nuck
Post Number: 1538
Jan translated says WTF was the first post!?
Username: Stridergt
AthensGreec e
Post Number: 19
I guess I should not have mentioned the age of the speakers (anyway I love their sound)... But instead of nba trotters jokes I do not get, I could use some help by someone who knows what that thing is...
Username: Nuck
Post Number: 1542
Sorry, George, I have the idea now.
Yes you can reattach the retainer ring with ordinary adhesive.
Username: Timn8ter
Seattle, WA USA
Post Number: 803
http://electronics.howstuffworks.com/speaker3.htm
Username: Stridergt
AthensGreec e
Post Number: 20
Ok thanx everybody, you were right Nuck, according to Timn8ter's link, it is a dust cap! Since it is not playing any role sonically I won't bother puting it back. The thing is that one of the pair plays a bit louder-brighter than the other (tried with different amps too), and I thought the metallic cap was to blame, but I guess they got tired playing so/for many different genres/generations...
Username: Stridergt
AthensGreec e
Post Number: 21
nuck it was not the retainer ring your initial thought -dust cap- was the correct one.
Username: Loce
Lilburn, GA
Post Number: 36
George, for more information about reparing these older speakers, you might consider visiting www. audiokarma.org.
