Bronze Member Username: Vic_in_explorer
Sanford,
Florida
United States
Post Number: 42 Registered: Jul-05
Posted on can someone also tell what is a good amp with solid power and a resonable price. |
Post Number: 6525 Registered: Dec-03
Posted on Define reasonable price. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 7683 Registered: May-04
Posted on Define "good amp". |
Bronze Member Username: Paulfolbrecht
Post Number: 85 Registered: Dec-05
Posted on You could spend $60,000 on a pair of SET monoblocks that put out 3W/ch. These are good amps. The price is pretty reasonable too, really. I'd buy a pair.
Gold Member Username: Nuck
Parkhill,
Ontario
Post Number: 1480 Registered: Dec-04
Posted on Hang around, Vic. It gets worse before it gets better. What do you want to do with this amp, and what kind of pre-amp do you have/want? |
Serniter Unregistered guest |
Posted on Maybe specifying the speakers you intend to use it with and room size might help?  |
Dallas,
TX
Post Number: 7706 Registered: May-04
Posted on "What do you want to do with this amp, and what kind of pre-amp do you have/want?" ? "Maybe specifying the speakers you intend to use it with and room size might help?" ???
Parkhill,
Ontario
Post Number: 1496 Registered: Dec-04
Posted on Vic?..You Home? |
Parkhill,
Ontario
Post Number: 1497 Registered: Dec-04
Posted on Vic is dead..something fell on him..a piano we think, we don't have all the details yet...WKRP. |
