Need quick help with Paradigm surrounds
Rock_Hard
Right now, i have Paradigm Mini Monitors for the rears and i would like another set of paradigms for the back to incorporate 7.1 surround. I need to mount them on a wall so i need them to be quite small...do you guys know a good paradigm i should be looking for? i'm more than likely going to have to look on ebay because there is no Paradigm dealer in my area. any help is appreciated! thanks
Username: Gavincumm
New York USA
Post Number: 709
if you need them to be quite small, take a look at the speakers in the "cinema" package systems. They are a bit larger than Bose, and can really pump out the sound, and do it well. For small surrounds in a paradigm system, they will be perfect!
just look for cinema 70, cinema 90, or just paradigm cinema and see what comes up!
Rock_Hard
Is it possible to just buy rears from the packages?
Username: Artk
Albany, Oregon USA
Post Number: 2822
Both the Atom and Titan come ready to wall mount. The mounting brackets are seperate and cost $25 or $30 bucks.
http://www.paradigm.com/Website/SiteParadigmProduct/ParadigmModels/Performance/P erformanceSpecs.htm
They aren't a perfect voice match with the Mini's but they work together very well.
Rock_Hard
Thanks very much! next question...if i don't come across a set on ebay, what's a good place to get Paradigm from?
Username: Gavincumm
New York USA
Post Number: 710
a dealer...
you can't get them online
Username: Gavincumm
New York USA
Post Number: 711
but you can also look at www.audiogon.com for used and like new ones as well
Rock_Hard
I would buy them from a dealer but nobody in my area carries them.
thanks for the website.
Username: Artk
Albany, Oregon USA
Post Number: 2826
I'm going to be offline for a few days but I would ask you to check the Paradigm dealer locater for a dealer near you. You can call one and they will sell them to you and ship them.
