Deree-greece Unregistered guest | I am looking to outfit a weightroom with a new stereo system. The room is about 60' by 120'the roof is about 25' hi. It is a large concrete box with windows on one wall. I really don't know what I need or want. Clearity might be a far cry for this type of room, so I guess I just need some volume. any info on how many speakers I should look into getting, or how many watts the reciever should be would be a great place to start. I would like to stay under $2000, but would rather spend more to get a better deal then be stuck with crap. Also should I be looking into outside speakers? Any feedback would be great. |
Silver Member Username: GavincummNew York USA Post Number: 707 Registered: Feb-05 | I would give klipsch corporation a call and see what they come up with. 1-800-KLIPSCH |
Silver Member Username: TwebbzAnn Arbor, Michigan USA Post Number: 358 Registered: Apr-04 | Stuff designed for home use is not what you're looking for. You should probably contact a commercial operation to get speakers mounted up on the walls out of your way. They'll know how to power them too. Check these out for starters... http://www.peavey.com/products/browse.cfm/action/drill/cat/95/begin/1/ImpulseSer ies.cfm www.electrovoice.com www.jblpro.com |
Silver Member Username: ChitownPost Number: 805 Registered: Apr-05 | I don't think he will get anywhere in the pro line stuff with $2000. |
Silver Member Username: TwebbzAnn Arbor, Michigan USA Post Number: 359 Registered: Apr-04 | Hey, Sure!!! Peavey Kicks Butt! A couple of either of these with an integrated amp and tuner and he's all set. $339.99 Each http://www.peavey.com/products/browse.cfm/action/detail/item/84029/number/003604 60/cat/100/begin/1/Impulse%AE+100+Two-Way+Molded+PA+Enclosure+%28Black%29.cfm $579.99 Each http://www.peavey.com/products/browse.cfm/action/detail/item/100794/number/00442 530/cat/100/begin/1/Impulse%AE+1012+8+ohm+Two-Way+Molded+PA+Enclosure+%28Black%2 9.cfm |
Silver Member Username: ChitownPost Number: 806 Registered: Apr-05 | For a room that size he will need at least four of these. That will blow his budget without even an amp. |
Silver Member Username: TwebbzAnn Arbor, Michigan USA Post Number: 360 Registered: Apr-04 | He said..."like to stay under $2,000 but would rather spend more to get a better deal." This will at least point him in the right direction and give him an idea the cost of what he's looking for. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3658 Registered: Mar-05 | I'd look at some of the cheap pro amps discussed here: http://www.avsforum.com/avs-vb/showthread.php?t=418666 And pair them with some Cerwin Vegas or, if budget allows, Klipsch. |
Silver Member Username: TwebbzAnn Arbor, Michigan USA Post Number: 361 Registered: Apr-04 | Doesn't seem like Klipsch has much to offer. Maybe this... http://www.klipsch.com/product/product.aspx?cid=538 On the other hand, Cerwin-Vega has some offerings... http://www.cerwinvega.com/products/newpro/index.html |
Silver Member Username: GavincummNew York USA Post Number: 714 Registered: Feb-05 | as I said... thats why he needs to give them as CALL! the reps can answer the questions better than any one of us can. |
Silver Member Username: TwebbzAnn Arbor, Michigan USA Post Number: 362 Registered: Apr-04 | This is not rocket science. I've been a gym rat for 25 years and the last thing one would want to do is blast music while people are trying to workout. It's a social thing too so people need to be heard when they converse. In this type of situation what one would want is backround music at low to moderate levels. Speakers that are too large are just unnecessary. The Peavey speakers are made to be suspended or attached to a wall up out of the way of the equipment. Four of them would be plenty. I've seen this type of setup before and it works just fine. We're not talking about a dance bar here. It's a gym! By the way, the Peavey company has been around a long time and they make a quality product. |
