Anonymous | I'm looking for a sub around $500. Mostly for watching movies. |
Silver Member Username: GavincummNew York USA Post Number: 703 Registered: Feb-05 | if you can up your budget by $99, I would say the MartinLogan Dynamo hands down. In the price range that you specified, I would look at HSU research. |
Bronze Member Username: ShowridesHartford, CT USA Post Number: 27 Registered: Feb-06 | SI mag 15 would be great. I just got a 12 for my HT and will hopefully have it all up and running for you all to see this weekend. I just wanted something I knew would be loud and would hit all the lows I wanted to hit in my HT setup. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7656 Registered: May-04 | Unbeatable quality for the money: http://www.us.alegriaaudio.com/Tom%20Subwoofer.htm |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3653 Registered: Mar-05 | for mostly movies I'd get the SVS PB10 if you want the really low low LFE. otherwise the Mirage S12 at vanns.com is a great deal, b-stocks are just $340, and a-stock $400 shipped when they come in a few weeks from now. |
Silver Member Username: GavincummNew York USA Post Number: 706 Registered: Feb-05 | the PB10 is unabashedly boomy for music use, eddie. Therefore it really negates its use as a HT sub. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3654 Registered: Mar-05 | > the PB10 is unabashedly boomy for music use, eddie. Therefore it really negates its use as a HT sub. ??? The OP wrote his use is "mostly movies." Why would he care if the PB10 is "boomy" for music? |
Bronze Member Username: ShepyjayOnt Canada Post Number: 55 Registered: Feb-06 | find an authorized psb dealer and listen to an alpha sub woofer |
Silver Member Username: GavincummNew York USA Post Number: 716 Registered: Feb-05 | ed... re-read my post please... it said and I quote "therefore it really negates its use as a HT sub" if you have a sub that can't reproduce music properly, you will still end up with a $hitty sub, no matter what. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3665 Registered: Mar-05 | I disagree. HT just requires going as low as possible while being as loud as possible. That's why SVS subs are so popular for HT, and rightfully so. Music requires the sub to be really precise and fast, and extension under 30-35Hz is pretty much superfluous. Unless you are one of the .005% of people who watch movies just to listen to the music soundtracks of course. |
Silver Member Username: GavincummNew York USA Post Number: 723 Registered: Feb-05 | to each his own... I still can hear and feel the difference. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3667 Registered: Mar-05 | I don't doubt that. |
Gold Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 1486 Registered: Feb-04 | Lots of people on the forum have the Hsy STF-2 and like it. I have the STF-3 and I'm really happy for both movies and music. |
Silver Member Username: GavincummNew York USA Post Number: 801 Registered: Feb-05 | the HSU subs are great! |
