Need some help
Username: Copper2
Texas
i have a bose acoust 15. I am using a a receiver from yamaha(HTR-5660). The receiver only pushs 90 watts rms. Someone told me that if i get a better receiver my system will sound much better and the bass will also. Is this true? I only have $700 to spend if it will make a difference. Anyone have any suggestions.
Username: Project6
Post Number: 6356
Are you stuck with Bose or are you open to other speaker choices?
Username: Copper2
Texas
no not really. willing to replace all for better sound. don't know if it is the rec. or the speakers
Username: Project6
Post Number: 6360
Try changing speakers first. The one significan tmove you can do for better sound. What is available in your area?
What is your budget?
