New member Username: TustseguaPetaling jaya, Selangor Malaysia Post Number: 1 Registered: Feb-06 | ok im really new to these stuffs..and currently JUST started learning about sound engineering..erm..im just confused by the terms or i do not really get what it means..so i hope you pros could educate me a little.. 1)what is a crossfire? 2)Basic Monitor Positioning Checks: * Ensure that the monitors are all placed at the appropriate angle for the reproduction channel, e.g. in stereo left monitor ia at 30° from centre, etc. * Measure the distance to the side walls and the wall behind the monitors of the left/right stereo pair and ensure they agree to within 1 centimeter. Do this for the front AND rear left/right pairs in a 5.1 surround system * For the best stereo imaging ensure that the side walls and the front wall behind the left and right monitors are similar. If not, this may affect the response * Ensure the furniture and equipment in the room has precise left/right symmetry * Clear the space between you and the monitors from all unnecessary equipment, e.g. computer screens and piles of rack equipment, so that there is a clear view from all the monitors to the listening position (taken from www.genelec.com) erm..i dont really understand what does the word monitor means in this passage,izit a speaker or? 3)what's a battlefront? so far..that's about it..i hope you wont be annoyed by this noob questions >< |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7628 Registered: May-04 | Yes, it's a speaker. The "bafflefront" is the portion of the speaker which mounts the drivers. I didn't see the word "crossfire" but it would probably mean having the speaker's axes cross at your listening position. In other words they are pointed directly at you. |
Bronze Member Username: N8d1Baltimore Post Number: 30 Registered: Jan-06 | Maybe he meant crossover? If so, a crossover is used to separate the frequencies and send them to the appropriate speaker/driver. You don't want low frequencies going to your tweeters nor do you want your high frequencies reaching your subwoofer, etc. |
New member Username: TustseguaPetaling jaya, Selangor Malaysia Post Number: 6 Registered: Feb-06 | hmm..thanks..i think that answers my question..yeah i think its crossover..not cross fire..sorry! |
