I am putting together a new computer build and want to use it as a source for a 2 channel system in my bedroom to play pop music, classical piano and guitar, and some light jazz. I am going to go from a Chaintech AV-710 to a T-amp. I can get some used Monitor Audio Bronze B4 speakers for $300. Is that a good price? Has anyone used these speakers with a t-amp? I know it will not produce high volume, but my room is small and I like good clear music at reasonable volumes. I am not really a big bass fan, so that is not a big issue. Any suggestion? Thanks!
With the T amp, you are better served by buying the most efficient, good sounding speaker you can afford. Go to the "Amps" section of the forum and read "Buy this amplifier".
