New member Username: ScientistPost Number: 1 Registered: Feb-06 | hi. i am an audiophile. i am crazy about music. it is my first day on this site. i have a pair of grand piano home sonus fabers, they sound great they are hooked to denon avr 5805 with monster m 2.2 cable while setting my home theater , the custom installer suggested to use 4 channels of the receiver(each is 170 w rms) to bi amp the speakers. the speakers are rated at max of 250. he says it will sound better, i am worried i will blow up the speakers. can anybody help me. thanks |
Gold Member Username: Project6Post Number: 6252 Registered: Dec-03 | Welcom to the forum ihab. Go here: http://www.soundstage.com/synergize/synergize031998.htm |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 1203 Registered: Sep-04 | ihab You're more likely to blow up your speakers with a weedy amp than one that's "too powerful". A weedy amp will distort and try to make a speaker do things it's not designed to do. A powerful amp will simply drive it as far as it will go. Now, if it tries to go too far, the main drive units will 'pop' when they hit their end-stops, but you're less likely to break them this way. regards, Frank. |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1403 Registered: Dec-04 | ihab, as an 'audiophile', with a 170w receiver, do tell your equipment. |
Gold Member Username: Project6Post Number: 6258 Registered: Dec-03 | I think he meant "audiophile" in a totally different context. In this case - one who likes to listen to audio, not necessarily a connoiseur. |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1410 Registered: Dec-04 | I dig |
Silver Member Username: GavincummNew York USA Post Number: 663 Registered: Feb-05 | I take |
Gold Member Username: Project6Post Number: 6271 Registered: Dec-03 | I really don't like that word audio-phile...sounds like some perv who gives the "bad touch" to stereo equipment |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1416 Registered: Dec-04 | I dunno...proper audiophyles don't expose themselves, except to their dealers. Regular audiophiles are want to wander. |
Gold Member Username: Project6Post Number: 6279 Registered: Dec-03 | Are they required to register...I wonder? |
New member Username: ScientistPost Number: 2 Registered: Feb-06 | Thanks for all your input my gear denon dvd 5901 denon avr 5805(170 w x 10) monster power center 5100 signature monster avs 2000 signature sonus faber grand piano home floor standers 4 B& w in wall speakers 600 series fpm6 central speakers fpm 4 as second surrounds. definitive technology supercube 1 subwoofer thanks |
Silver Member Username: KanoBC Canada Post Number: 846 Registered: Oct-04 | *sigh* why is it that those with the best cars don't know how to drive. |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1477 Registered: Dec-04 | Ihab, you need rehab. You've got the audio bug bad...but good. Did you check Berny's link at the top? |
New member Username: ScientistPost Number: 3 Registered: Feb-06 | Nuck why do i need rehab and why a bug!!! please explain. do i have any bad link in my gear. and what Beny's link to check. i am new to this site, remeber thanks for your input |
Gold Member Username: Project6Post Number: 6499 Registered: Dec-03 | ihab, I believe he was being jovial ![]() No insult intended, if there was one you'll see it...he has not earned the rank of subtle artist yet. He is complimenting your gear. Clik on the link I provided down below. http://www.soundstage.com/synergize/synergize031998.htm |
New member Username: ScientistPost Number: 4 Registered: Feb-06 | Another question I am between setting a 9.1 and a 7.1 is it really worth it. I want to do 7.1 for movies, and for music i want both a 2.1 with the sonus and a 9.1 with sonus and 7 B & w speakers. I just want to get the most out of my gear since i have it. some cds are better in the 2 channel mode , others in multichannel. the avr 5805, i think has no 5 channel audio mode but it has all channel audio, so that is why the 9.1. I hope the audessey eq system will set all 9 speakers optimally. let me know what you think. thanks |
Gold Member Username: Project6Post Number: 6753 Registered: Dec-03 | Its worth is totally up to you. Why not experiment with your gear and decide which setting you like best? No one can really tell what is worth what. |
