Ipod shows empty, but space is still shown used
hey all, my ipod appears to be empty, i had 3K songs then one night they were gone and it shows nothing under artists, songs, etc. however, when i plug it into the computer all my data files are still there as well as the space occupied by the songs on the ipod. any ideas???? also the songs dont show up on itunes when plugged into the comp either
Username: Corner23
Hey the same thing just happened to me 2 days ago!! My Ipod had been charging all day then I unplugged it and all my songs were gone!?! What gives? My ipod doesn't even show up in itunes anymore. I'm so upset. I am going to try the ipod updater on apple's website.
yea no kidding, 3K songs not there for my listening pleasure, im very angry bout it.
Username: Gerardiux
HI, I HAD THE SAME TROUBLE, I'VE SEARCH ALL THE WEB, THE ONLY THING I COULD DO WAS TO PUT IN WINDOWS TO YOU ALL SE FOLDERS, GO TO THE IPOD IN "MY COMPUTER" AND THEN ENTER TO THIS FOLDER "E:\iPod_Control\Music" AND THERE ARE ALL THE MUSIC, THEN COPIED ALL TO MY COMPUTER, RESTORE THE IPOD, PUT ALL THE MUSIC IN THE ITUNES, AND SEND IT AGAIN TO THE IPOD. IT WORKS FOR ME
SALUDOS
GERARDO
Username: Ftalife
Post Number: 179
You try the rest?
Username: Ftalife
Post Number: 180
Does it show empty in the itunes also?
Username: Ftalife
Post Number: 181
http://www.apple.com/support/
You may have to download the newest software.
