I think I have decided..
Username: Purplelabel
Maracaibo, Zulia Venezuela
After a whole day reading and reading I think I will buy Mirage Omnisats or Polk 6900, but I have a problem, The receiver I would like to buy is the Yamaha HTR 5890,so, Which set of speakers will run better on it? Remember I cannot check the sound of this systems because I live outside US. Thanks for any help
milagro
The Omnisats are better speakers and would probably sound better on that Yammie.
Username: Rysa4
Post Number: 387
I agree with the unregistered guest.
Username: Project6
Post Number: 6211
You should be happy either way. You have no other speakers to compare against:-)
Username: Gavincumm
New York USA
Post Number: 624
on yamaha, I would also throw in Paradigm. I JUST RECENTLY heard a paradigm monitor system paired up with a yamaha reciever and it wasnt bad at all.
but I will also state that mirage is a great company
