Wnat Speakers to buy ????Please Help
Username: Purplelabel
Maracaibo, Zulia Venezuela
Hello, I am willing to buy a new set of speakers for using with Pioneer VSX-1015TXK 7.1 Channel Surround Sound
and I have in mind specifically this packages:
*Polk RM 20 Set of Speakers (wich are my favorites)
*Bose Acoustimas 5 Series III + Bose Vcs30
*JBL SCS300.7 Home cinema audio
*Infinity TSS750
Any recommendations?
Username: Project6
Post Number: 6188
Can you listen to all of these speakers where you live?
Listen to them for yourself. Bring your own music. Listen well. Then decide which ones you like.
Username: Tdogroeder
Des Moines, IA
Post Number: 97
You should go with what you like best. Only by listening will you be know what sounds best to your ears. Because all you will get is biased opinions if someone tells you what brand to go with.
That is the problem I don't have any source or store here where I can listen to all the equipments that I have researched for a few weeks, so my ears are your ears...here are some aspects for mi research: very solid, never get easily burned, good for movies and for loud music, wall mounting decor' style,and not too expensive. I will appreciate any true help.
Thanks again
Any Help?
Username: Chitown
Post Number: 775
I think based on that list you should effectively leave the Bose and that JBL off and concentrate on the other two. The Bose is no good and the JBL set is really no more than PC speakers (albeit good ones), but still sounds tiny.
Username: Rysa4
Post Number: 384
Mirage Omnistats might your needs.
Marc Sherman thanks for the advice but now that I've checked Mirage OmniSat Omnipolars...How could I build a 5.1 system?, there is no center channel and rears, what do you recommend for this? Also, between Polk RM 6900 & Polk 20 which one you'll get? Thanks in advance
