New member Username: AmautaPost Number: 1 Registered: Feb-06 | Good day folks. Im new to the website and im hopeful to get some possitive feedback on this. I want to build a audio system for my computer, but i dont know what exactly i need. I was planning on building a Speaker and the the title box, i think its name is subwoofer. Thank you. |
Silver Member Username: DanmanQUEBEC CANADA Post Number: 620 Registered: Apr-04 | Why do you want to build 1000 watts for a computer system??? You ould do a lot better in seperates with less wattage and 1000 times superior sound! |
New member Username: AmautaPost Number: 2 Registered: Feb-06 | Well, what i actually wanna do is to have a powerful bass. Now that you mention less power with separate speakers i think it might be better. I was looking only for bass systems but they seem to be pretty expansive so i decided to build one. so far i know i need Two Speakers[left and right] an amp and woofer, the amp i must buy, but id like to build the woofer. Any advice on that? |
Gold Member Username: Project6Post Number: 6143 Registered: Dec-03 | You want to build a woofer? Why not just get a woofer that's already built and just put it in your own enclosure?![]() Here's a good place to start. http://www.partsexpress.com/ |
