Stereo vs. Hi-Fi (?) shelf system
Username: Couts
I just purchased Sony Shelf system CMT-HPZ9. I failed to note the small words "Micro Hi-Fi Componet System", CMT-HPZ9. 170 total watts rms. I unpacked it, but not yet installed. I thought I was buying a Stereo. Sooo, (1)would someone explain the difference between Hi-Fi and Stereo on shelf systems? (2)Is one preferred over the other? (3)Any comments on this system would be appreciated. Thanks!
Username: Project6
Post Number: 6882
You have a stereo hi-fi, don't worry too much about the terms. Unpack it...listen to it, if you like it, keep it.
Need to Register?
Forgot Password?
Enable HTML code in message
