HELP with Receiver
Username: Txgator
I just bought a Pioneer VSX915K and hooked up my Bose Acoustmas speakers and I get no sound. The Auto setup identifies my speakers and subwoofer and says everything is fine. I have tried tuner, TV, and DVD with no sound.
I have seen this problem in stores more than once and figured it out when the salesman could not. Check the speaker setting on the receiver. The one that selects which speakers play such as A or A B
Username: Lane
Idaho
Ed,
Probably not a source problem (TV, DVD, etc) but an output - speaker problem. As above, check the speaker selections and you should be fine..
Username: Txgator
Post Number: 7
Thanks. I left the speakers connected and disconnected everything else. Then ran the Auto set up again and it worked great. Reconnected DVD and Tv all worked good. The rcvr is great.
