Bronze Member Username: Kinggimp82Post Number: 30 Registered: May-05 | what are the benifits of bannana plugs over bare wire? does it just make connecting the wire easier or do they make a better connection? any info would be helpfull. andrew |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1387 Registered: Dec-04 | Andrew, straight plugs(banana), are very good for #1, quick connects (like setup andbreakdown for the band). #2, the design and depth of the plugs make a natural support for especially heavy cable(as well as dual solder connects for redundancy in the connection). If your amp/receiver is not designed to support the weight, they will cause problems. Other than that, they are as good as twisted wire posts. |
Bronze Member Username: Kinggimp82Post Number: 31 Registered: May-05 | one other thing. does thicker speaker wire increase sound quality? i use 12 gauge wire now. would 10 or 8 gauge wire be better? |
Bronze Member Username: PraetorianPost Number: 85 Registered: Dec-05 | Depending in your system ofcourse, but 12 AWG is probably the point of "diminishing returns" for sound quality per se. |
Silver Member Username: GavincummNew York USA Post Number: 598 Registered: Feb-05 | Im certain that you could hook your speakers to your amp with re-bar if you like... but would it really be worth it? I wonder what that would sound like. Not only that, you'd have to have a big s$$ binding post to support it. lol |
Gold Member Username: Project6Post Number: 6128 Registered: Dec-03 | re-bar...hmmm |
Stan Pigme Unregistered guest | Gavin, rebar would not be as good as antique lamp cord wires terminated with cotton balls and piano wire to a antique tube radio. |
Silver Member Username: Timn8terSeattle, WA USA Post Number: 773 Registered: Dec-03 | Banana plugs are nice for quick connect/disconnect but if they don't have strong gripping strength you may regret using them. Good ones are fine, stay away from the cheap ones. |
Jan Pigne Unregistered guest | Banana plugs are good for when I am lonely. |
Silver Member Username: TdogroederDes Moines, IA Post Number: 101 Registered: Sep-05 | What is a good bannan plug? I'm using Acoustic Reasearch proseries II PR407's, are these good ones? |
Silver Member Username: Timn8terSeattle, WA USA Post Number: 774 Registered: Dec-03 | http://www.madisound.com/wbt.html |
Bronze Member Username: Dodgedifferent2Windsor, Ontario Canada Post Number: 81 Registered: May-05 | I picked my nanner plugs up at radio shack I use the solderless ones and have yet to see anything wrong with them. I personally find it much easier to set-up my system when i move every year. I even have my wires now color coded to make it that much easier. |
Gold Member Username: Project6Post Number: 6250 Registered: Dec-03 | You gotta go what you gotta do It makes the reassembly much easier. |
