Help on upgrading!
Username: Unreal_t
United States
Im planning to upgrade my Yamaha YHT-450 Home Theater in a Box system
You can see the specs and all here:
http://www.amazon.com/gp/product/B0001XAJDO
I have had for a year now. I have a few questions though...
Im planning on replacing the two front L and R speakers with either the Polk R50's or Monitor 50's I cannot see the difference between them actually. The other choice is the JBL E 80's.
I can get the JBL's for $300 a pair and the polks for $400 a pair. Im more of a Polk fanatic but never experienced JBL's yet.
I also plan to replace really junky 6 inch Sub with a Polk PSW10 which I can get for $100 brand new. The center I got with the Yamaha YHT-450 system sounds nice and the surrounds arent't bad so I'll keep those and save some money. Im planning to stay under $500 dollars for the two fronts and sub so maybe someone can suggest something better than what Im considering?
Will the Yamaha HTR-5740 Receiver I got with the system be good enough to power the 2 new fronts and sub I get?
Any advice at all is appreciated.
THANKS!
