Make my speakers wireless
Are there any transmitters and receivers out now that I can hook up to regular speakers and a receiver so that I can place the speakers I have now anywhere in my house? If so what and where can I find them?
Thanks.
Username: Jan_b_vigne
Dallas, TX
Post Number: 7562
Duct tape a Walkman and a battery powered Sonic T amp to the back of your speakers.
Username: Timn8ter
Seattle, WA USA
Post Number: 767
Jan's farcical response has some truth to it. Consider what you're asking for. First, you need a transmitter at the source, one for each channel assuming you're not going monaural which also means the two channels will need to be broadcasting on different frequencies that don't interfere with each other at close range. Then at the speakers you'll need matching receivers for the transmitters. From the transmitters you'll need amplifiers, once again, one for each speaker. Unless you're running high sensitivity speakers a decent monoblock is going to be spendy. All this adds up to BIG BUCKS and you still may wonder about the quality. Plus you'll still need a power cord so are they truly wireless? On the other hand, if you want to go the cheap route you could try Googling "make speakers wireless" and you may find a cheap X10 system.
Dallas, TX
Post Number: 7565
Farcical?! That was my solution after using extension cords on my home stereo to get better sound from my car stereo. It would have worked except for those old ladies crossing the street.
Not to mention having to come home in the reverse direction I left. Problems, problems, problems.
Username: Nuck
Parkhill, Ontario Canada
Post Number: 1376
Jan, the old ladies crossing the street were actually European woman of unknowwn descent, with beards, looking, oddly, like the Beatles.
On Abby Road.
Dallas, TX
Post Number: 7570
Not so! They were all wearing shoes.
Of sorts.
Username: My_rantz
Australia
Post Number: 269
Lucky they didn't cause a toe jam!
Dallas, TX
Post Number: 7571
I couldn't tell. I wasn't listening to the radio for reports.
Username: Roberts
Redmond , WA USA
I read these forums to learn and share my passion with audio and I keep running into the same arrogant
fool with the not very entertaining remarks. Parts express has something like what you want Shawn.
