Matching speakers for marantz SR7000
Jarrod
I am looking getting some new speakers to match my Marantz SR7000 reciever, can anyone suggest a speaker that would best compliment it in the US$500-800 mark? I am after a speaker with a little bit of 'punch' as I am not currently running a sub, but would also like the option of getting on later.
Any suggestions?
Username: Project6
Post Number: 5821
Athena ASF-2.2
You just want a pair, right?
Jarrod
yeah, to be honest I am a little new to this, my last set up was an old sony amp with four minipods. I have opted for something with more power and want to get the most out of it. A pair of front speakers and maybe some rear ones as well, what would you suggest?
Username: Project6
Post Number: 5844
Check out audio advisor.com
They have great prices on the Athena line up, really plays well with Marantz and should fall within the top mark of your budget.
I cannot however, recommend the Athena sub, I feel that it is the weak link in an otherwise great speaker set. But you did say you are going to get the subs later on, the ASF-2.2 puts out a decent amount of bass and depending on your taste, probably won't need a sub.
Username: Jarrod_w
Thanks for your help. Am off to visit some audio places this weekend to get some more options.
