My Marantz CD 72 has only one channel working with RCA analog cables connected. But it works fine with coaxial digital cable. What can be the problem? Is it easy to fix? Thanks.
Marantz CD 72 has two sets of RCA jacks, one fixed and the other variable. So, four RCA connectors in total . Among these four, only two left channels (fixed and variable, which are on the top) work while neither of the two right connectors(on the bottom) sings. I opened the CD player and couldn't find anything wrong with the connector--they look tight and sturdy. No loose sold joint can be easily indentified either.
