New member Username: Topcat25Sayreville, NJ USA Post Number: 2 Registered: Feb-06 | Any outdoor speakers out there that sound good but are not expensive? |
Bronze Member Username: PatnshanWisconsin USA Post Number: 23 Registered: Aug-05 | I use audiosource. They are very cheap and sound fine for the money. Pat |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7513 Registered: May-04 | Cheap, huh? Walk through your neigborhood and then steal the one's you like the most. |
Silver Member Username: GavincummNew York USA Post Number: 540 Registered: Feb-05 | take a look at the Onix outdoor speakers from av123. They will probably be your best bet for great (not just good) sound at a decent price. they are $99 a pair, and if they are anything like the rest of their speaker lines, which have been getting amazing reviews from consumers and pros alike, these wil lbe WELL worth your money. http://www.av123.com/products_product.php?section=speakers&product=44.1 it depends on what you classify as expensive, but I highly doubt you can get better outdoor speakers for that price. |
New member Username: JsbEvanston, IL Post Number: 8 Registered: Jan-06 | Tom - at www.tweeter.com, the Mirage Oasis MKII is $89 a pair. Not a speaker that I have heard, but looks like a good deal for a 2 way outdoor speaker with 6.5 inch woofer. I would also look at Onix as Gavin mentioned. I have one of their subwoofers and it is rock solid. |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1304 Registered: Dec-04 | Jan, I thought you was in a good 'hood. |
Silver Member Username: GavincummNew York USA Post Number: 581 Registered: Feb-05 | or you could always use those Bose 101's that we all know that Nuck has secretly stashed in his closet. heehee your guilty pleasure is out in the open! |
