Can ipod be connected to AVR to give quality stereo sound?
juggy_25
can ipod be connected to the AV Receiver thru the RCA? how does it sound??
Username: Nadz
California
Post Number: 30
It can sound great but it all depends on the quality of the MP3 files you are using. Low bit rate files at 128 and such will sound poor. If you use 256,320 or lossless you will get great sound. Not like a good CD player but quite good.
Just get the adaptor and your set.
Username: Frank_abela
Berkshire UK
Post Number: 1198
Rate for rate, AAC sounds better than MP3 from an iPod. You can either plug the iPod in using an interconnect with 3.5mm jack to 2 RCAs (phonos). Or you can connect something like an Onkyo base which also allows you to remote control the iPod...
Regards,
Frank.
