Technical question
adam R
I want to buy a set of speakers that are designed for a portable dvd player. Does anyone know if I can use the speakers with my minidisc player? The speakers are Panasonic Sc-hdx2. Thanks for any help.
alan
I'm guessing that the speakers are active, pc type, ones. This means that they have an amp built into them. There should be a lead to connect your dvd to the spekers, this lead should also go into your minidisc, if the connector is not right buy and adaptor from maplin (UK) at http://www.maplin.co.uk or from radioshack (US)
