I guess anyone as dumb as I am should not be allowed to own audio equipment but I do. I have a Yamaha RX-V640 reveiver with Paradigm speakers and need to know if I should use + or - dbs when setting my speakers. Is the + dbs louder or is the - dbs louder. I told you I was dumb. Thanks. Soldierboy
I think Joe is talking about the individual volume settings for each channel. To answer your question unless you have a strange speaker placement keep all volume settings at "0". If your center channel is a bit higher or lower, more than 24", than your FL and FR speakers you may want to increase it's volume.
