Which Receiver? NAD T773 or Boston Acoustics AVR-7120
Username: Upsidedown
Any thoughts or comments? The NAD would be a demo.
Username: Project6
Post Number: 5288
I love the sound of NAD. Just make sure that the unit you are getting does not have any hum/hiss issue.
Username: Fatelvis
Good luck! I just went through two T743s... both went back. Both had hum (only with certain Dolby Digital 2.0 sources), and one had worse hiss than the other. Neither sounded as "lush" as my classic 7240PE. I'm seriously considering picking up a 3240PE to run rear channels and calling it a day.
Of course, SpearitSound accused me of "looking for problems" --> but these forums have provided a solid sanity check on both issues. To their credit, they tried to make me happy.
Username: Project6
Post Number: 6016
Jeff, what did you end up getting? Or did you not get any new equipment?
Username: Gman
Mt. Pleasant, SC
Post Number: 830
The NAD's don't have firewire, HDMI, or DVI. Depending on your budget, your room size, the speakers you choose, and what you want your receiver to do, there are many other options.
Username: Project6
Post Number: 6070
The future of audio equipment. So many options.
