Bronze Member Username: DjwagesPost Number: 25 Registered: Jan-05 | Just wondering if upgrading to a Marantz SR7500 or 8500 would be a worthwhile upgrade from an Onkyo TX-NR801. I'm looking for better 2-channel performance but still want the surround quality and from what I've read the Marantz has it. I have a Marantz 2252B from the 70's that blows the Oink out of the water so having another Marantz had some attraction. I've also considered the NAD lines. Any other suggestions? Thanks |
New member Username: StevoMargate, FL. USA Post Number: 9 Registered: Apr-04 | I'm looking at the Marantz SR8500. Or the Outlaw 990/7700. Putting them with Paradigm studio 60s cc570 and 20s. I like the Marantz sound with the Paradigms. haven't heard the Outlaw yet. Does anybody have the Outlaw 990/7700 with the Paradigms? If so how does it sound? |
Silver Member Username: ChitownPost Number: 716 Registered: Apr-05 | Go to a local audio store and check out the Marantz and decide. I'm not a big fan of Onkyo, but I don't know how much of an upgrade you would get by spending this money. |
Bronze Member Username: Tommy_jenkinsTallahasse, FL Post Number: 12 Registered: Dec-05 | The 7500/8500 are much more musical but for the money you could just add a 2-channel external amp to your Onkyo, or upgrade your mains if needed. What speakers are you using? |
Bronze Member Username: DjwagesPost Number: 28 Registered: Jan-05 | Mirage M490s. 8" ported, 6ohms with 86db sensitivity. My vintage Marantz really wakes them up with incredible bottom end, almost too much. But the Oink is flat. More specs here: http://www.miragespeakers.com/PDFs/classic_manuals/90/M-490/M490brochure.pdf |
Bronze Member Username: Tommy_jenkinsTallahasse, FL Post Number: 13 Registered: Dec-05 | You could consider just adding this for your 2-channel listening: http://www.audioadvisor.com/store/productdetail.asp?sku=MARAPM7200&product_name= PM7200%20Integrated%20Amplifier%20-%20Black |
Bronze Member Username: DjwagesPost Number: 29 Registered: Jan-05 | Thanks. I used to have a B&K and regret ever getting rid of it. I'm considering another B&K and using the Oink as the Preamp, but the Marantz IntAmp looks nice also and would eliminate any Oink from the equation. |
