New member Username: Dante_the_scrub
Post Number: 1 Registered: Jan-06
Posted on Hi - Do you know of a compact stereo system (CD/tape/tuner) you can plug a turntable into? New or vintage. If a system has only a generic ground-less aux input, is there a way to connect a turntable? I'm looking to replace old components with something smaller. But want to play records too. Thanks.
