John Wagner Unregistered guest | Has anyone heard these speakers, one person over on audio reviews said that he like these more than some Magnepan 3.6's! http://www.audioreview.com/mfr/rbh-sound/floorstanding-speaker/PRD_124719_1594cr x.aspx |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7372 Registered: May-04 | OOOOOOhhhh! One person! JW, you can find one person to like anything. OK, so your mother doesn't even care for your constant harping; but somewhere, JW, ... |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1141 Registered: Dec-04 | They sound better than"some" Magnepan 3.6's only if you stick little green polka dots on them. |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1142 Registered: Dec-04 | And putting it in CAPS doesn't make them better either. |
Gold Member Username: Project6Post Number: 5062 Registered: Dec-03 | Yes, but I'm sure that it will be 40% better if he used contact enhancer. |
Silver Member Username: DavidpaPortland, Oregon US Post Number: 116 Registered: Nov-05 | unless it rains. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7379 Registered: May-04 | Th, th, th, that's all, folks! |
