Paradigm OW Monitor 5 Series - opinions needed
Beastie1
I would like to know how they sound. I do not have a local dealer in which I can preview them so I need advice.
I am in a position to only mount "on the wall: next to my plasma - hence I am considering these and also the Paradigm Cinema 360s
How do they sound over all?
Are they good enough to serve in the front as mains?
Any more pros and cons would be great.
Thanks,
Username: Eld
Texas
Post Number: 18
Beastie1,
Check into Martin Logan Vinette (wall mounted speakers) for your center, left and right.
Username: Gavincumm
New York USA
Post Number: 504
the fresco is much better than the vignette
