Home theater system
Username: Siva_19742002
Hi all,
I live in chennai,India. I am planning to buy a 7.1 channle home theater system. i.e. receiver and speakers package. I have two choices.
1. Onkyo
2.Denon
Please tell your opinions that which choice should i take.
Username: Project6
Post Number: 4945
Make your own decision. Listen to both and trust your ears.
Username: Edster922
Post Number: 3589
Denon.
Username: Frank_abela
Berkshire UK
Post Number: 1162
I'd go with the Denon too.
Username: Gman
Mt. Pleasant, SC
Post Number: 789
It all depends on your budget (including speakers), your room size, and what performance you hope to get from your system. You can't really choose a receiver in a vacuum of information.
Username: Chach169
I have a panasonic big screen tv with a pioneer 1015tx receiver and 5 bose speakers. DVD works great with surround sound. TV only get sound from 2 or 3 front speakers and I cannot get on screen guide. Where does the tv plug into the receiver? I have lots of connections on the back of the tv. Which one do I use? DVD is currently plugged into DVD in on receiver. Cable is plugged into TV/Sat in. If I plug TV directly to receiver TV/Sat in I get no sound.
Username: Project6
Post Number: 5053
Have you consulted the manual?
Are the DVD's audio output connected directly to the TV?
You really should start a new thread instead of hijacking this one. Probably why you don't get a lot of responses.
