Bronze Member Username: Blazer
Post Number: 65 Registered: Feb-04
Posted on I just purchased Dynaudio 52's to use as the front mains and was wondering which center to consider. The 122c or 42c? Thanks for your input! |
New member Username: Eld
Post Number: 9 Registered: Dec-05
Posted on Blazer, Since the center does a huge amount of work in a surrond system, I recommend getting the 122c. |
Bronze Member Username: Allen
Post Number: 11 Registered: Sep-05
Posted on If you use HT most of the time then get the 122c.If your main concern is two channel music then the 42c is fine and you can still save some money. |
